| Version(s): | 2004, XM, & V8i | ||
| Area: | |||
| Subarea: | |||
Dec 2014, AutoPIPE V8i 09.06.01.10
All the SIFs calculated automatically by AutoPIPE are in accordance with the manual calculation except for the bends. Why?
Be sure that the calculations adhere to all the code calculation notes. Example, per ASME B31.3-2010, Appendix D, welding elbow, Notes: 2, 4-7.
Note: most hand calculations do not consider note 7 and thus show a difference with AutoPIPE results. Correctly applying the factor from note 7 generally accounts for the difference.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
