| Version(s): | 2004, XM, & V8i | ||
| Area: | Import | ||
| Subarea: | |||
Dec 2014, AutoPIPE V8i 09.06.01.10
Is it possible to load a live AutoPLANT model database into AutoPIPE to perform analysis without having to export a pcf or pxf file?
We apologize for the inconvenience, but at this time with AutoPIPE 09.06.xx.xx and lower, the only way to open an AutoPLANT file in AutoPIPE is by importing an AutoPLANT PXF file. AutoPIPE cannot open an AutoPLANT data base file only.
If you like to see this function in AutoPIPE, Please log an enhancement request. The more requests for an enhancement the quicker the functionality will be added to the program.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
