| Version(s): | 2004, XM, & V8i | ||
| Area: | Modeling | ||
| Subarea: | |||
To Modify piping only, first turn off the Frame members using View > Hide Components (select Beam).
Alternatively make the beams transparent (However while good for viewing the beams can still accidentally be selected when modifying the piping)
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
