| Product(s): | AutoPIPE | ||
| Version(s): | V8i | ||
| Area: | New Users | ||
| Subarea: | |||
AutoPIPE and Caesar are both 2 iconic programs that perform the same functions; Pipe Stress Analysis based on pipe arrangement, pipe properties, and applied loads. Although these applications have the same end goal, provide stress analysis results, they are different programs with different methodology. This WIKI is to help new users of AutoPIPE that had used Caesar before, but have now migrated to AutoPIPE.
Non-linear Load Sequencing Explained
AutoPIPE vs Caesar load combinations
C-Node or Connecting Nodes in Caesar
Compare AutoPIPE Input Grids with Caesar Spreadsheets
Dynamic Load questions :
1. Dynamic load factor
2. The default % value of critical damping used in Caesar II
Are answered on the following WIKI page: Dynamic Analysis in AutoPIPE
Modeling Support - AutoPIPE
1. Item #8: Modeling Guide Supports
2. Item #11: Define a Displacement at a Support
Are answered on the following WIKI page: Modeling Support - AutoPIPE
Error message:
The load case did not converge. Do you wish to continue iterating?
Graphical Point Editing
Caesar users are used to looking at the model, then reading and entering the point name. In AutoPIPE like CAD use point and click, point names are automatically taken care of.
Productivity Example - Add a Support
| AutoPIPE | Caesar |
Pipe Stress Work involves lots of Iterations
99 levels of Undo / Redo are available at all times in AutoPIPE such that different support configurations can be tried and if stresses or equipment loads are worse then can easily revert back to some previous state. But in Caesar undo/redo is always lost when exit the INPUT module.
Alphanumeric node numbering by segments – easy to identify which nodes relate to which parts / line numbers of the model
Defining Wind, Wave, and Earthquake Loads
Go to the Load menu to define them
Note: Up to 10 (AutoPIPE V8i 09.06.00.xx and lower) or 30 (AutoPIPE V8i 09.06.01.xx and higher) seismic loads are available useful for evaluating +X, -X, +Z, -Z as a minimum for non-linear cases. (Only 3 uniform loads available in Caesar). Similarly up to 10 wind cases available in the one static analysis.
Define a displacement at a support
In AutoPIPE simply assign a displacement at the support for any load case, GR, T1, T2, E1, etc during modelling. Caesar has limitation of defining only 9 displacements which have to be combined in post processing to specific load cases. Insert > Xtra data > imposed support displacement. These can be applied also to anchors but only act in the direction of the restraint.
Download file:
Caesar_autopipe_Translation_5.pdf
File contains information on the following topics:
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
