Before Running our OHDOTCEv02_AdminTools Installer, it is important to understand how Bentley's CONNECT products configuration works. Our Installer ONLY configures our workspace, YOU must ensure that our workspace is then correctly configured into the CONNECT products. This video will show you how to do just that!
