Printing DGNs to PDF with Digital Signature fields
The following video shows how to print DGNs file to PDF and also generate digital signature fields in the PDF during the printing process as well as how the print styles, configuration, and design scripts are set up.
Please note that the functionality to create digital signature fields from design scripts only works in CONNECT Edition products. MEANING if printing from v8i then the design scripts WILL NOT create digital signature fields!
https://youtu.be/RkYBbr3IEM0
