Electronic Design Deliverables - L&D Vol 3 Section 1600
1600 - Electronic Design Deliverables | Ohio Department of Transportation
This document specifies the requirements for the following two deliverables
  1. PDF Plan Set
  2. Supporting Documents Zip File - How To
