Can I access ProjectWise Drive offline/without internet?
Answer
Yes, your ProjectWise Drive allows you to work on cached local copies of files you’ve opened. You can also add/modify files, just keep in mind that these changes will not be loaded to ProjectWise until you are online/with internet.
