Office product doesn't open in ProjectWise Explorer. Am I doing something wrong?
ProjectWise Integration – Microsoft Office Suite
  1. Open the Office Suite application that needs to be integrated with ProjectWise.
  1. When in the Office application, select "File" in the top left of the window.
  1. From the File menu, select "Options" in the bottom left.
  1. Once in Options, select "Add-ins"
  1. On the bottom of the "Add-ins" menu, next to "Manage", select the COM Add-ins from the drop down and press go.
  1. Inside COM Add-ins, make sure the option for ProjectWise iDesktop Integration is checked on.
  1. If the ProjectWise iDesktop Integration option is still not working in your office application or that option is not available under the "COM Add-ins" section, check the "Disabled Items" drop down option.
  1. Inside "Disabled Items", check that ProjectWise iDesktop Integration is not on this list of disabled add-ins. If it is listed here, select the add-in and hit Enable.
