OHDOT Geometry Points
The ODOT Geometry Points tools is an add-in for OpenRoads Designer that allows reviewing both Geometry Points and Survey Points in one dialog.
https://youtu.be/flFBS1WldM0
Version 1.0.1.0 Updates
https://youtu.be/qoqNzHjniyo
Version 1.0.1.3 Updates (Monument Report, Custom Reports, Alt. Station Output)
https://youtu.be/01y_zUpTujY
PDF Help Doc
