This installer was renamed from OHDOTCEv02_AdminTools_Installer to OHDOTCEv02_WorkSpaceTools_Installer.
This Installer will install the OHDOTCEv02 WorkSpace setup tool and the OHDOTCEv02 Standards Sync Tool. Running this installer is the first step to setting up the OHDOTCEv02 workspace. the next two steps would be to run the two previously mentioned tools.
The installer can be downloaded from our CADD downloads page here.
There is also documentation for this installer, which can be found at the link below. Please note this document is not a walkthrough guide, it is to document the available options and what they do/mean within the application.
https://ftp.dot.state.oh.us/pub/CADD/CADDSync/OHDOTCEv02/OHDOTCEv02_WorkSpaceTools_Installer.pdf
Video does contain YouTube chapters (only seen if watched on YouTube)
