Electronic Design Deliverables - Digital Signatures - Project Submission
This section of our wiki provides the following,
Project Submissions - Overview
Internal Project Submission via ProjectWise Procedure - How to
Guidelines for Electronic Design Deliverables
PDF Plan Set
Supporting Documents Zip File - How To
Creating LandXML Alignment files in ORD
Creating LandXML Surface files in ORD
Creating 3D Linestrings DGN files in ORD
Digital Signatures - Overview
Steps for creating digitally signed plan sets
Changes to Title Sheet Layout for Digital Signatures
Adding Digital Signatures and Seals to Title Sheets
Printing DGNs to PDF with Digital Signature fields
Unable to find file 'OHDOT-eSign.dscript' error
Adding Digital Signature Fields directly to PDF
Getting an image of your signature to use when Digitally Signing PDFs
Using Signature Image Creation App
Scan/Image of handwritten signature
Creating Digital Signatures Appearances (Adobe and Bluebeam)
Signature Validation Icons Guide (Adobe and Bluebeam)
Creating PDF Packages (Adobe and Bluebeam)
FAQ
Links to manuals that pertain to this topic:
Location and Design Manual, Volume 3 - Highway Plans
OHDOT CADD Engineering Standards Manual
(moved to
section 1200 of L&D Volume 3
(moved to
section 1600 of L&D Volume 3
Real Estate Manual - Section 3000
Project Submission Procedure (internal only)
