This wiki describes the procedure for requesting a folder or a file(s) restore from a Bentley Cloud Hosed Datasource. If the folder or file(s) have been inadvertently deleted, check the Deleted Items container in the datasource first. Files stay in the Deleted Items for 6 months before being purged.
Note: Restoring a .dgn may require a Reference Scan if the file referenced, or was referenced by, other documents.
Name Display Name
OhioDOT-pw-02 Ohio DOT Projects
OhioDOT-pw-03 Ohio DOT Archive
OhioDOT-pw-04 Ohio DOT Training-Testing
Note: Restores will primarily be from: OhioDOT-pw-02 Ohio DOT Projects
Folder ID – The Folder ID of the folder containing the folder or file(s) to be restored can be found in the View Pane title bar, (see below).
Folder path – Select the folder that contains the folder or file(s) to be restored and copy the path from the Address bar, (see below).
Go to the Bentley CONNECT Center and login using Bentley IMS login.
Once logged in select New Case by selecting the icon shown below.
You'll open a panel scroll and select the New Case or you can scroll down on the webpage to find the New Case button.
Select Technical Support.
Fill out the Technical Support form as shown below. A restore request should be addressed by Bentley Support within 4 hours, though it may be next day before the file(s) appears in the datasource. You should receive an email when the file(s) has been restored indicating the location in ProjectWise.
Copy 1-6 into the Details field as shown below, editing as appropriate:
Select your Name and Email from the drop-down menu shown below:
Fill in the remainder of the form as shown below:
Click the Submit button on the right side of the screen.
After submitting, you should see the screen below. Your case number will be available in two locations.
You will also receive the email notification below with the corresponding case number included.
When the file(s) has been restored to ProjectWise you will get email notification with the location of the restored file(s)
The Bentley tech will typically place the restored file(s) in the ZZ_Restore folder with the Case number (Ex: CS123456), as shown:
There are a few options when returning or replacing the file to the project file(s) location in ProjectWise:
If you need further assistance, feel free to contact OHDOT CADD Services via our Service Request form here.
