Leica ASCII Export/Import (FRT)
This page walks through the workflow and settings needed to use the OHDOT Leica PNEZC with Attributes.FRT file to generate an ASCII import for OpenRoads Designer.
https://youtu.be/6CDSkvhG7nQ
This video walks through where to find the OHDOT Lecia FRT format file as well as how to import the ASCII export option in your Leica data collector.
Link to FRT file (OHDOT+Leica+PNEZC+with+Attributes.FRT)
https://youtu.be/C8lRJAWHsJI
This video walks through the data collector settings and files needed to export an ASCII formatted for OpenRoads Designer and the OHDOT CADD standards.
https://youtu.be/ld-qAiSgFeg
This video walks through the settings and workflow for importing the OHDOT format Leica ASCII file into OpenRoads Designer.
*Please note when using the FRT file format with attributes that include the " symbol an error will occur on import. We are working on a solution with Bentley support. In the meantime, please remove the " symbol to continue the import.
