Supplemental Videos
See below for a list of help videos.
Coordinate Systems
Geographic Coordinate Systems (GCS)
Auxiliary Coordinates (Lat/Long)
Survey
Import Survey Data from CSV
Reviewing Survey Data
Terrain Model Creation and Editing
Creating a Complex Terrain
Creating a Terrain Model from a Point Cloud
Importing a Shapefile from ProjectWise
Adding a Linear Feature to an Existing Field Book
Terrain Model to Terrain Model Heat Map
Leica ASCII Export/Import (FRT)
Geometry
Civil Accudraw Overview
Civil Accudraw Accuracy Tip
Adding Ordinates to Civil Accudraw
Design Standards
Geometry Builder
Table Editor
Transform Existing Alignment
Transform Rotate Parcels/RW
Annotation (alignment, annotate model)
Construction Limits
Import ASCII Points
Templates
OHDOT Delivered End Conditions Overview
OHDOT End Condition Templates, Fixed Ditches Overview
OHDOT End Condition Templates, Fixed Ditch Example
Add Subgrade Component to Template
Cross Section
OpenRoads Designer Cross Section Seeding Calculation Workflow
OpenRoads Designer Annotating Cross Sections (Guardrail & Right-of-Way)
Corridors
Corridor References
Point Controls
Parametric Constraints
Superelevation
Superelevation Overview
Create Superelevation Sections
Review and Edit Superelevation
Assign Superelevation to Corridor
Review Superelevation
Import Superelevation from CSV
Adding Lanes to Superelevation
Modeling
Cul-De-Sac Modeling
Guardrail Modeling
Annotation
Alignment Annotation Options
Alignment Curve Set Annotation
Fix Duplicate Profile Annotations
Creating an Annotated Profile for Preliminary Review
Cross Section Annotation
Override Alignment Annotation
Drainage and Utilities
New Drainage & Utility Features - Fix compatibility issue
Extracting Utility Features
Modifying/Custom Utility Profiles
Extracting Existing Drainage Features
Placing Headwalls
Modeling Proposed Drainage Features - Placing Nodes and Conduit
Modeling Proposed Drainage Features - Place Nodes Tool
Creating Profile Runs
Profile Run Sheets
Setting up Drainage to show on Plan And Profile Sheets
Showing Drainage on Plan and Profile Sheets
Setting up Utilities to show on Plan and Profile Sheets
Setting up Utilities to show on Plan and Profile Sheets - Alternative Workflow
Showing Utilities on Plan and Profile Sheets
Drainage and Utilities Annotation Overview
See
this
time stamped video for Drainage and Utility Annotation
Plan view Drainage Annotation
Profile View Drainage Annotation
Cross Section View Drainage Annotation
Station Offset Annotation - Drainage Annotation
Annotating Utilities in Profile Views
Annotating Utilities in Cross Section Views
Importing User Defined Extensions into Existing Projects
Custom Conduit Sizes in ORD Drainage
Custom Conduit Sizes in ORD Utilities
Changing Defaults for Utility Extraction
Sheets Clipping
Container Files
Plan Sheets
Profile Sheets
Bridge Site Plan
Level Management
Adjust Profile Named Boundary
Miscellaneous
Accu-Draw
Using Auto-Table within ProjectWise Explorer
Common Auto-Table Scaling Problems
Importing OSIP Data into ORD (Internal ODOT Workflow)
ProjectWise
Opening multiple Instances of a program
ProjectWise Explorer: Logging into ProjectWise
ProjectWise Explorer: Functionality
ProjectWise Explorer: Advanced Search
ProjectWise Explorer: Browsing Folders and Work Areas
ProjectWise Explorer: Creating Folders
ProjectWise Explorer: Copy/Move Folders
ProjectWise Explorer: Delete Documents/Folders
ProjectWise Explorer: Custom Folders
ProjectWise Explorer: Reference Resolver
ProjectWise Explorer: AuditTrail
ProjectWise Explorer: Creating a Shortcut to an External Location
ProjectWise Explorer: Managed Exports for Non-Integrated Applications
ProjectWise Explorer: Local Document Organizer
ProjectWise Admins: User Management
ProjectWise Web: What/Who/How
ProjectWise Web: Connected Project Overview
ProjectWise Web: Adding Users To Connected Project
ProjectWise Web: Connected Project External Organization
ProjectWise Web: Connected Project Share
ProjectWise
General Summary
Understanding how GenSum and Sub-summaries link to Item Master
YouTube Playlist on the General Summary sheet
YouTube Playlist on Automating the Creation of General Summary from sub-summaries.
Fix: GenSum refresh item master not working
