Frequently Asked Questions (FAQ)
OpenRoads Designer FAQ's
Frequently Asked Questions and Common/Known Issues of ODOT’s Migration to Bentley’s OpenX 2024 Platform of Productions (OpenRoads Designer, OpenBridge Modeler, OpenGround, etc…)
Ohio DOT – OpenRoads Designer Best Practices for Level Management for Plan Sheet Production
How do I delete my ORD User Preferences?
How do I make a backup of my preferences?
How to I fix the "Last Error [222]" message when opening a file in 10.12?
How do I fix a Parametric Headwall Cell Wingwall angle issue in ORD 10.12?
ProjectWise Drive FAQ's
Can I access ProjectWise Drive offline/without internet?
I am signed into ProjectWise Drive, but it is not showing in Windows File Explorer. Why?
I cannot see my files, or my files will not sync to ProjectWise. Am I doing something wrong?
What do all the icons mean under "Status"?
Why do I continue to receive notifications about invalid file path names?
ProjectWise FAQ's
Creating File Versions in Projectwise
Creating Document Versions
Modifying Version Information
Copying Documents with Versions
Moving Documents with Versions
Deleting Document Versions
Versioning DGN Files with References
How do I restore a file?
Option 1 Replace File with Version
Option 2 Replace File with Export
Option 3 Replace File
Why isn't my Office product not opening in ProjectWise Explorer?
Unable to Check-in "Last Error [58002]"
