This page consists of OHDOT Ideas that have been submitted to the Bentley Idea Portals. The intent of this page is to provide an easier way to view what OHDOT thinks is important to add to future version of Bentley Software. The table below provides links to each of the Ideas so that the user can help boost the number of votes on the ideas so that they have a better chance of being implemented into a future version of software.
| ID | Priority | Ideas Portal | Title | Link | |
| MSR-I-1298 | High | MicroStation | Add functionality of Unit formatting when creating table from report. | Link to Idea | |
| BCI-I-1312 | High | OpenCivil | ORD Drainage - new properties for gutter spread/depth at edge of grate (not center) | Link to Idea | |
| BCI-I-383 | High | OpenCivil | Enhance Annotation Definitions | Link to Idea | |
| BCI-I-940 | High | OpenCivil | Import parcels, survey chains, lines, curves, spirals from GPK | Link to Idea | |
| BCI-I-1321 | High | OpenCivil | Plan-Profile-Profile drawing/sheet creation with named boundaries | Link to Idea | |
| BCI-I-287 | High | OpenCivil | Ability to Delete specific Annotation group instance instead of all instances | Link to Idea | |
| BCI-I-979 | High | OpenCivil | ORD Seeding Reports Like GEOPAK | Link to Idea | |
| BCI-I-1206 | High | OpenCivil | Enhancing Named Boundaries: Updating Named Boundaries and Applying Geometry Rules | Link to Idea | |
| BCI-I-340 | High | OpenCivil | Need a Manage Modifications options in Annotation Groups for points | Link to Idea | |
| NA | High | MicroStation Programming | Add a CreateCellInstance method to place a cell from a cell library | Link to Idea | |
| BCI-I-1220 | High | OpenCivil | Superelevation reassign | Link to Idea | |
| PWDI-I-482 | Medium | ProjectWise | Option to restrict access to ProjectWise Messenger | Link to Idea | |
| PWDI-I-487 | Medium | ProjectWise | Get Link to ProjectWise Drive | Link to Idea | |
| MS-I-402 | Medium | MicroStation | Update Text editor with useful features | Link to Idea | |
| BCI-I-1382 | Medium | OpenCivil | End Area Earthwork Corrections for Curvature | Link to Idea | |
| BCI-I-108 | Medium | OpenCivil | Automate Node Labeling in Cross Section Drawings | Link to Idea | |
| BCI-I-112 | Medium | OpenCivil | Text favorite to honor math expressions | Link to Idea | |
| BCI-I-127 | Medium | OpenCivil | Ability to Place Geometry Points that use Parametric Cells | Link to Idea | |
| BCI-I-164 | Medium | OpenCivil | Button to synchronize all template drops for all corridors & linear templates in a file | Link to Idea | |
| BCI-I-256 | Medium | OpenCivil | Ability to create XS from Line String (More than 2 points) | Link to Idea | |
| BCI-I-807 | Medium | OpenCivil | Use Analyze Point Tool in Sheet/Drawing Models | Link to Idea | |
| BCI-I-461 | Medium | OpenCivil | Ability to export and import all corridor objects such as point controls to enable rebuilding of corridors | Link to Idea | |
| BCI-I-664 | Medium | OpenCivil | Ability to create a Profile Drawing Model "Without" creating a Sheet Model | Link to Idea | |
| BCI-I-101 | Medium | OpenCivil | OBM should support multi-model, 2D and 3D workflows similar to OpenRoads | Link to Idea | |
| BCI-I-931 | Medium | OpenCivil | Ability to toggle Survey point decorators when referenced to other files | Link to Idea | |
| PWDI-I-380 | Medium | ProjectWise | Support ZIP document | Link to Idea | |
| BCI-I-1457 | Low | OpenCivil | Civil Accudraw Reference Element Included in Heads Up Prompt and Highlight Element | Link to Idea | |
| PWDI-I-321 | Low | ProjectWise | ProjectWise Dark Mode UI | Link to Idea | |
| PWDI-I-484 | Low | ProjectWise | Extra Large Icon (Larger Thumbnails) | Link to Idea | |
| PWDI-I-485 | Low | ProjectWise | Change Click and Drag Function | Link to Idea | |
| PWDI-I-488 | Low | ProjectWise | Better Document Restore Process | Link to Idea | |
| MSR-I-1299 | Low | MicroStation | SDK request to add a function to .net API to allow removing a GCS from model | Link to Idea | |
| BCI-I-1227 | Low | OpenCivil | Don't reset terrain FD when changing scale | Link to Idea | |
| BCI-I-1305 | Low | OpenCivil | ORD Drainage - Make Item Type Properties available in flex tables | Link to Idea | |
| BCI-I-841 | Low | OpenCivil | Get quick slope measurement from dynamic XS | Link to Idea | |
| BCI-I-1383 | Low | OpenCivil | Template Library Folder Configuration Variable | Link to Idea | |
| BCI-I-105 | Low | OpenCivil | Show and annotate projected points on profile view | Link to Idea | |
| BCI-I-120 | Low | OpenCivil | Ability to annotate models over a station range | Link to Idea | |
| BCI-I-1429 | Low | OpenCivil | Combining Properties Menus | Link to Idea | |
| BCI-I-159 | Low | OpenCivil | Use Parametric cells for creation and management of sign structures and sign bridges | Link to Idea | |
| BCI-I-286 | Low | OpenCivil | Ability to make Geometry Profile models indexed dgn models | Link to Idea | |
| BCI-I-291 | Low | OpenCivil | Improve "Create Terrain from Design Meshes & Graphical Filter Tools | Link to Idea | |
| BCI-I-440 | Low | OpenCivil | Make Template Editor a non-modal window. | Link to Idea | |
| BCI-I-458 | Low | OpenCivil | Want a way to use sheet index property as a text favorite in annotation | Link to Idea | |
| PWDI-I-283 | Low | ProjectWise | PW Explorer and Admin UI redesign | Link to Idea | |
| BCI-I-121 | Low | OpenCivil | Ability to annotate slope between linear features in plan using the Civil Labeler | Link to Idea | |
| BCI-I-1036 | Low | OpenCivil | OpenRoads Designer Keyin List | Link to Idea | |
| BCI-I-658 | Low | OpenCivil | Drawing Model Optional | Link to Idea | |
| BCI-I-383 | Low | OpenCivil | Enhance Annotation Definitions (Add text frame option and associate leader line to text) | Link to Idea | |
| BCI-I-604 | Low | OpenCivil | Ability to Synchronize ITL to a Master ITL | Link to Idea | |
| BCI-I-246 | Low | OpenCivil | turn on "settings from design model" via variable for all sheet seeds | Link to Idea |
Bentley Portal Links:
OpenRoads Designer Ideas Portal
ProjectWise Design Intergration Ideas Portal
