GeoPak Road tools issues
We had an issue with GeoPak Road Tools this morning (Microstation V8).  Whenever the user tried to use the Plan View Labeler Microstation and GeoPak would crash and abort the session.  Other road tools options seemed to work fine, it just seemed to be the plan view labeler that was having issues. We tried different files and projects with the same result.
The user was trying to access the plan view labeler through the road tools toolbar when he was having the issues.  However if he used the road tools pulldown to access the plan view labeler it would appear to work fine.  He closed the toolbar and reopened it and everything seems to be OK, but I would like to know it there was something more at play here.
Could this be just a temporary glitch with the toolbar? or is there something else that may be an issue?  I have the exception log that was generated when the program crashed if that would be of any help to someone. Any help would be greatly appreciated.  Thanks
Steve
