GEOPAK Bridge
Bentley's GEOPAK Bridge is object-oriented software for modeling bridges. It offers intelligent bridge components that promote fast, dynamic design and facilitate design modifications. GEOPAK Bridge is fully integrated with MicroStation and the GEOPAK Civil Engineering Suite, providing you easy access to essential transportation design information while modeling in a powerful, interactive environment.
The software includes a Bridge Project Explorer that offers an intuitive way of working with bridge components, subcomponents and their properties. You can generate bridge alignments with Alignment Manager, or use alignments created in GEOPAK Civil Engineering Suite or GEOPAK Site. Bridge deck surfaces can be defined with GEOPAK Bridge Surface Manager, a flexible means to creating deck surfaces that includes using the superelevation shapes from your GEOPAK roadway data.
