This Client Server article is republished in its entirety from 2005 for reference purposes.
By Bentley Technical Support Group, PE, MX Support Manager, Bentley
23 May 2005
Bentley offers three civil engineering highway design packages, based on the MXROAD, InRoads, and GEOPAK product lines. Originally, these solutions were developed by competing vendors, and had completely different database structures and different terminology to describe the data. Each of these vendors realized that customers needed to transfer design data between packages, and there needed to be a standard for design data transferability.
All three became part of the LandXML.org organization, which developed the industry standard called LandXML.
LandXML, now adopted by many software developers, is used specifically for intelligently moving civil engineering design data between different software packages.
It is important to emphasize that LandXML is for the exchange of design information. It is not for exchanging drawing information.
Bentley now owns the MXROAD, InRoads, and GEOPAK packages, and continues to develop them. Bentley continues to improve the implementation of the LandXML standard in each product line.
This article will give tips on how to transfer civil engineering design data between the MXROADS, InRoads and GEOPAK.
LandXML.org is a non-profit organization with many vendor members. Together, these members developed an industry data definition standard that could be read by many application programs, and to which many applications could write, without relying on individual vendors' terminology or data standards.
While LandXML offers great benefits to users who need to exchange design data between software applications, it won't magically convert a complex design in another application, leaving it ready to go. Different applications work in completely different ways. The LandXML is a neutral file format, and each application does the best it can to create data in this format, from its own data format.
When you generate LandXML files:
When you are given a LandXML file to process:
Exporting is a simple process. In short, you simply tell the software application what to export, and it does it:
Select File > Export > LandXML...
You can import all data into a single MX feature, but that won't give you much information in MX about the data.
The preferred method is to map each element in the LandXML data to features in MX. This allows you to distinguish between centerlines, road edges and other features that may be contained in the LandXML data.
The more effort you make in mapping the features, the better your end results will be.
Select File > Import > LandXML...
You must tell MX how to map the LandXML elements to MX models and strings, otherwise, no data can be imported.
You can import COGO data, surface data and alignment data into MX. In all data types, you will need to identify the model name to put the data into, and the feature and style sets associated with the data.
You should always define a default mapping, and preferably, the individual feature mapping to get good data.
Mapping COGO Data
Mapping Surface Data
Mapping Alignment Data
By default, the export and import of LandXML is not available in the menus. You have to turn this feature on:
On the main InRoads menu, select Tools > Application Add-ins
Scroll down to the bottom of the list. Make sure that XML Report Add-In is checked on
Select OK
Exporting LandXML Data from InRoads
LandXML data is exported in two separate stages: surface and alignment. Designs can be exported both as a surface and as alignments.
The surface contains the features. To export a design surface you have to model the road before exporting.
Existing terrains would only be exported as a surface, as they usually don't have alignments.
How to Export Alignment Data
Make sure that you have the road project(s) open. In the InRoads main menu select File > Open, and select the project(s)
Select File > Translators > LandXML
Identify the Geometry Project and the Alignments to be exported
How to Export Surface Data
On the InRoads main menu, select File > Translators > LandXML
Identify the items such as triangles and features you wish to export.
Importing LandXML Into InRoads
LandXML data is imported in one process and assigned to either surface or geometry depending upon the data found:
Importing Alignment Data
Make sure that you have the road project open with the correct geometry. In the InRoads main menu select File > Open, and select the project(s)
All geometry found in the XML file will be imported as alignments. With surface data, by default, InRoads will automatically assign a single feature type to imported data, however, if you have features defined in the LandXML file, and in the Feature Style Manager, additional mapping will take place.
LandXML data is exported in two separate stages: geometry and DTM.
How to Export Geometry Data
The export LandXML geometry functionality is accessed from within the COGO dialog:
Select File > Export > LandXML 1.0 Geometry
Specify your project name and description, and also the element type and whether to export both Points and Chains. If you choose to export chains, you can also export your profiles.
How to Export DTM Data
DTM data is only exported in the form of a TIN: the actual DTM (the GEOPAK DAT file) is not exported. Hence you have to create the TIN from the DTM data before exporting.
In the DTM Toolbar, select Utilities > Export LandXML
From the COGO dialog select File > Import > LandXML 1.0 Geometry
How to Import DTM Data
The DTM export LandXML functionality can be accessed from either the DTM Toolbar or from the DTM Tool Palette
In the DTM Toolbar, select Utilities > Import LandXML
Notes on Importing into GEOPAK
InRoads Product TechNotes FAQs And Support Video Clips
GEOPAK TechNotes, FAQs and Support Videos
