The following resources are provided as a reference by Bentley's Technical Support Group. They encompass the Bentley InRoads products.
- Video: DA Design File Settings - Control Points Panel
- Video: DA Design File Settings - Data File Parsing Panel
- Video: DA Design File Settings - General Panel
- Video: DA Design File Settings - Linear Crossings Panel
- Video: DA DesignFileSettings_LinkingCodes
- Video: DA Export Field Book Data
- Video: DA General Introduction
- Video: DA Surface Clip by polygon
- Video: DA Surface Create Composite and export
- Video: DA Surface From Field Book Data
- Video: DA Surface from Graphical Data
- Video: DA Surface from LIDAR File to Create Surface
- Video: DA Surface from MicroStation Point Cloud Element
- Video: DA Surface from MIG Surface and combine
- Video: DA Surface from Raster File to Create Surface
- Video: DA Surface visualization manipulation and export
- Video: DA Survey Workflow - Data Adjustment
- VIdeo: DA Survey Workflow - Dynamic Link LF Editing
- Video: DA Survey Workflow - General Manipulation Of FieldBook Data
- Video: DA Survey Workflow - Graphic LF Editing
- Video: DA Survey Workflow - Import Control and Survey Data
- Video: DA Survey Workflow - Linear Features - Describe 3 AvailableTypes
- Video: DA Survey Workflow - Point List LF Editing
- Video: DA Survey Workflow - Review Point And Linear Features in data tree and details panel
- Video: DA Survey Workflow - Setup or Observation Editing
- Video: Import NED Topo Data
