Rule Creation
Property Based Rule Creation
Property based rule creation can be performed through a UI dialogue. Rule creation process can be expedited through csv import / export and MS Excel tools.
Advanced Rule Creation
Let's explore how to create complex property check rule like "Above ground concrete beams' cross section area should be within a reasonable range". We'll be using filtering using logical operators and WHERE clause.
