ProjectWise Design Validation checks the completeness and quality of BIM data which is critical for reducing risk and generating actionable insights. Design Validation allows project teams to define and apply standards, such as the right classification and availability of data, which may be contractually required, and systematically run checks on engineering designs.
ProjectWise Design Validation can also perform clash detection between different disciplines and between different design categories, such as equipment and pipes. Validation tests are conducted in the cloud and can also be run on any previous version of the iModel. Validating the completeness and quality of design data ensures that the digital twin is ready for its intended purpose and enables insights for better decision making.
