| Product(s): | InRoads | ||
| Version(s): | V8.5+ | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
This video gives an example of using the Text Import Wizard command to import data from a ASCII file.
Recorded in 1024 x 768 resolution.
