| Product(s): | InRoads | ||
| Version(s): | V8.7+ | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
This video demonstrates using notepad to make elementary edits to an XSL. Specifically, the "ListCoordinates.XSL" report is edited to change the Style column to display the Description for COGO points.
Recorded in 1024 x 768 resolution.
