| Product(s): | InRoads | ||
| Version(s): | V8.7+ | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
This video is the second part of two videos that demonstrate using notepad to make elementary edits to an XSL. In this video, a column is added to the "ListCoordinates.XSL" report to display the Style for COGO points.
(Recorded in 1024 x 768 resolution.
