| Product(s): | InRoads | ||
| Version(s): | V8.7+ | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
This video gives an example of the Horizontal/Vertical Maximum and Minimum constraints used to define the location of template points.
Recorded in 1024 x 768 resolution.
