| Product(s): | InRoads | ||
| Version(s): | V8.7+ | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
This video gives a simple example of using null points and slope constraints to construct the crown point of a roadway at the midpoint between two surveyed curb lines.
Recorded in 1024 x 768 resolution.
