| Product(s): | InRoads | ||
| Version(s): | V8.7+ | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
This video gives a simple example of using the Parent Component field in the Component Properties to control the display of components in a template.
Recorded in 1024 x 768 resolution.
