| Product(s): | InRoads | ||
| Version(s): | V8.5+ | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
This video gives an example of using the copy portion of surface command to reduce the amount of surface data in a existing ground DTM by cutting out only the surface data in the area of the project.
(Recorded in 1024 x 768 resolution. )
