| Product(s): | InRoads | ||
| Area: | Roadway Designer | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
After editing a template in Roadway Designer, how can a template be created from the edited template?
Right click in Roadway Desinger section view at desired station and select Display and the Display Template dialog box will appear. At Symbology, removed all Object that are checked and Apply, this will place your template in your design file. Add your template to a selection set. From Create Template select File>Import Template>Add template (define template), Apply. You are prompte to select orgin, left and right hinge point and your new template populates in Create Template. New Template will be created and can be renamed as desired.
