| Product(s): | InRoads | ||
| Area: | Reports | ||
| Subarea: | |||
| Original Author: | Andrea Garecht, Bentley Technical Support Group | ||
How to generate a report showing Station / Offset / Northing / Easting / Elevation for Geometry and Surface Features?
Go to Tools > XML Reports > Clearance. This will bring up the Clearance Report dialog.
Select the "From" object on the General leaf.
Next select either Horizontal Alignments, Cogo Points, or Features to specify the "To".
Finally, hit "Apply" and the Report Browser should automatically populate with the Clearance.xsl report. If not, right click on the Clearance.xsl report and select, "Set as Default Clearance"
