| Product(s): | InRoads | ||
| Version(s): | N/A | ||
| Area: | Survey | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
How can I import a SDMS survey data file?
You will first need to add the SDMS Translator Add-In. To do this, go to Tools > Application Add-Ins and toggle on "SDMS Translator Add-In". You will then use the command File > Translators > SDMS Translator to import files of this type.
