| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Where are the Horizontal and Vertical Element tools?
In order to access the Horizontal and Vertical Element tools, they must be adding in to the product. Go to Tools>Application Add-Ins and toggle on "Horizontal and Vertical Elements Add-In". Now the tools can be accessed through Geometry>Horizontal Element and Geometry>Vertical Element.
