| Product(s): | InRoads | ||
| Area: | Surface | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
What is the fastest method to annotate the left and right edge levels of a road profile?
The fastest method to annotate the left and right edge levels of a road profile would be Evaluation>Profile>Annotate Feature in Profile. At Annotate select the feature of your road profile. At Points, select Elevation.
