| Product(s): | InRoads | ||
| Area: | Tools | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Geopak has a GeographicalCogo, Map Check that allows the user to close and report on survey closure. InRoads Map Check reports on closer but for alignments. Does InRoads have a similar command as Geopak?
InRoads has Tools>XMLReports>Map Check. You would need to push that survey (Survey>Survey Data to Geometry) to an alignment and then use the XML Report.
