| Product(s): | InRoads | ||
| Area: | Survey | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
I have two survey points that are displaying the same symbology and they should not.
Both points have the same Named Symbology, remove Use One Named Symbology for All and assign a different symbology for each style.
