| Product(s): | InRoads | ||
| Area: | Roadway Designer | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Question:
How do I set the closed-shape component that is filled in my Template?
Within the template, identify the Style of your component. Edit the Line style to Fill, via Style Manger>Surface Feature Symbology>Edit Cross Sections Line. Be sure to select Apply after making your changes.
