| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Is there a way to convert an element(s) that have been drawn in MicroStation into an alignment element or can I convert multiple elements (drawn in MicroStation) that are connected into an alignment? There are times when MicroStation is used to do a preliminary design using tangent lines and maybe multiple curves connected without spirals (compound curve) and they are hard to recreate in Rail.
Add your graphic to a selection set. Within Import Geometry> From Graphics, select Resolve Gaps, Join Elements and All Selected Elements Added to Single Alignments before you select Apply.
