| Product(s): | InRoads | ||
| Area: | Surface | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Can I partially deleting a feature?
Yes, Surface>Edit Surface>Partial Delete. You will be prompted to Identify your feature (then Accept it) followed by Identify Starting Point and then Ending Point.
