| Product(s): | InRoads | ||
| Area: | Cross Sections | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
When I modify my cross section, are those changes reflected in my volumes?
Only if you write your edited cross sections back to your surface and refresh that surface in your cross sections (Evaluation>Cross Section>Cross Sections>Cross Sections to Surface).
