| Product(s): | InRoads | ||
| Version(s): | 08.11.07.536 | ||
| Area: | Roadway Designer | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
How can set my template to target a specific elevation?
Within Create Template, Edit your Component Properties (right-click on the end condition). Set your End Condition Properties Target Type to Elevation and key-in your desired elevation at Offsets Vertical and Apply.
