| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
How do I obtain the file needed for Vertical Design Checks within Geometry>Vertical Curve Set>Design Criteria?
Within the Design Criteria dialog box, select Browse. Then navigate to C:\Program Files (x86)\Bentley\InRoads Group V8.11\Data\imperial\Vertical Design Checks
