| Product(s): | InRoads | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
How do I erase superelevation and start all over?
From within Roadway Designer, right-click in the superelevation window. Select "Superelevation Display List". Right-click on the section you would like to delete and select "Delete".
