| | Applies To | | |
| | Product(s): | InRoads | |
| | Version(s): | 08.11.07.615 | |
| | Environment: | N/A | |
| | Area: | Geometry | |
| | Subarea: | | |
| | Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | |
Question:
How can I annotate only the cogo points that are inside a fence?
Answer:
- Using MicroStation, place fence around desired COGO points.
- Run the command Geometry>View Geometry>View Horizontal Annotation.
- In the View Horizontal Annotation dialog box, place cursor in the Cogo Points "Include:" field.
- Click on the "Filter" button.
- Use "Fence Mode:" option to select which points you would like to annotate inside the fence. Only points located inside the fence are available for selection.
