| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Why is the "Filter" button grayed out in dialog boxes, for example the Geometry>View Geometry>View Horizontal Annotation command?
In order for the Filter button to be accessible, you must place your cursor in one of the "Include:" fields on the dialog box.
