| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Why is the "Check Integrity" command greyed out and not available?
The "Horizontal and Vertical Elements Add-In" must be toggled on in Tools > Application Add-Ins for this command to be available within the product.
