| Product(s): | Bentley GEOPAK Civil Engineering Suite | ||
| Area: | Installation | ||
| Subarea: | |||
| Original Author: | Nico Roman, Bentley Technical Support Group | ||
How to configure the NCDOT workspace to work with PowerGeopak
For the NCDOT workspace to work with PowerGEOPAK, the "SiteStandardsCfg.dat" located in the "C:\NCDOT_V8CINFIG\NcdotWorkSpaceFiles" directory needs to be replaced with the attached DAT file, or the following lines need to be commented out:
#%if defined (_MSDRAFT)
# MS_RSRC = ${MSDIR}msdraft.rsc #Main resource file for PowerDraft
#%else
# MS_RSRC = ${MSDIR}ustation.rsc #Main MS resource file usually ustation.rsc.
#%endif
Or download replace the sitestandards.cfg with
