Applies To | |||
Product(s): | InRoads | ||
Version(s): | N/A | ||
Environment: | N/A | ||
Area: | Geometry | ||
Subarea: | |||
Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Although I imported my horizontal alignment using chord definition, the results are reporting the arc length instead of chord length.
Go to File > Project Options. Click on the Geometry tab and ensure that the Horizontal Chord Definition is set to "Chord" and Measure is set to "Along Chord".
