| Product(s): | InRoads | ||
| Area: | Cross Sections | ||
| Subarea: | |||
| Original Author: | Andrea Garecht, Bentley Technical Support Group | ||
When annotating cross sections, every vertex is annotated in the surface. What if the only thing required are specific features from the backbone?
This occurs when annotating the "Points" in the surface. See the screenshot below:
This option will annotate all the verticies from the surface(s) selected on the General leaf. If only specific features are needing to be annotated, use the Features folder in the same command to annotate the features in the cross section set.
Remember, it is required to display the features in the cross section set before they can be annotated.
